Twin Disc Conversion
Hi, When converting to twin discs is the domed dust plate on the r/h/ side of the bike replaced with an identical flat one as per l/h side and is the orig finish chrome . Bike is imported a4 Cheers G
Thank you tlc.The part I am referring to is 9.5 cm diameter with the 4 holes, the disc tab washers fit on the outside of that.It is described in the parts book as a dust cover41012-14. On the right at the moment is a domed version of the same thing which obviously wont fit with twin disc set up that is why I was wondering if you fit 2 l/h ones when converting.
The one on the right should be flat. The left one is raised to cover the speedo drive.
tlc wrote:ADRIAN H wrote:The one on the right should be flat. The left one is raised to cover the speedo drive.
The one on the left, speedo side, is flat whilst on the right it is raised to cover the spacer.
Having a bad day, (or is it week) I will get my coat.
ADRIAN H wrote:tlc wrote:ADRIAN H wrote:The one on the right should be flat. The left one is raised to cover the speedo drive.
Having a bad day, (or is it week) I will get my coat.![]()
Still appreciate you trying to help
Users browsing this forum: No registered users and 116 guests
