both wiers to the horns are live on my z1100r when you press the switch no sound . when you press the switch shoud it earth one of the wires .
both horns work tested direct to the battery
horns
if i put a seperate live/earth to the brown - black/ white the horn work so that says to me the switch is faulty but i have tryed anther rocker switch on the 2 wires and the horns do not work .if you put one of the wiers from the rocker switch on the brown then on the red and black the horns will work when you operate the rocker switch .
Users browsing this forum: No registered users and 178 guests
