Zephyr swingarm sleeve - how and where from?
trackdayrider
#1 PostAuthor: trackdayrider » Sun May 25, 2014 7:08 am
Hello all
signed up a couple of years ago with the start of a project Z1000, but things got a bit delayed by other issue (Like heart surgey!)
My previous posts appear to have vanished...
Anyway - back on track and want to get the bike back together this year.
So...
I did a quick search but didn't really find an answer so thought I might ask the advice of those more experienced in the solution I'm looking for.
Fitting a Zephyr 1100 swingarm into a z1000A frame?
I have read about "sleeving" the swingarm, but looking at it, it seems any sleeve would be a very thin affair?
what do I need and is there anyone local to Sheffield I could approach to get something made up?
Thanks in advance!
Mark
Reecy
Zephyr swing arm sleeve
#2 PostAuthor: Reecy » Sun May 25, 2014 10:17 am
Mark,
I did the zephyr swing arm conversion a few years ago on a Z1000 that I later sold -duh
Tony from Pitstop 01942 684684 (located in Leigh/Lowton near Z-power) did it for me
simple enough to do, he made it in 2 parts (can't remember why) but it fitted a peach and made the conversion easy
Don't hesitate -get over to have it done
Reecy
sanderz
#3 PostAuthor: sanderz » Mon May 26, 2014 11:00 am
+1 what Reecy has said. Have had a few parts done /made by Pitstop in the past. Good set of lads their, worth a call at least :up
http://www.pitstopmotorcycles.co.uk/
Wots up DOHC
Robw
#4 PostAuthor: Robw » Mon May 26, 2014 12:50 pm
I am not sure how similar the dimensions are between a Z1000j and z1000a but I made up a simple spacer on my lathe.
Dimensions are length 238mm od20.22mm id 16mm
Rob
big green bus
#5 PostAuthor: big green bus » Mon May 26, 2014 6:26 pm
I think a 550 zephyr goes strait in, nothing to do steve.w has done it :roll:
Jumbo
#6 PostAuthor: Jumbo » Mon May 26, 2014 6:36 pm
I have put a ZRX1100 swing arm into my Z1100R and basically used some steel precision tube with an OD 20mm and ID 16mm which I bought off Ebay.
LE to JOG on a z900
P.U.M.
trackdayrider
#7 PostAuthor: trackdayrider » Sat May 31, 2014 11:35 am
big green bus wrote:I think a 550 zephyr goes strait in, nothing to do steve.w has done it :roll:
got one of those as well (don't ask!... I ended up with 2 zephyr swingarms)
But thanks for the info guys...
Will get on and get it sorted
Mark
chasingdreams2014.blogspot.co.uk
Users browsing this forum: No registered users and 165 guests
