Hazard Switch
Wayne1960
Hazard Switch
#1 PostAuthor: Wayne1960 » Thu May 29, 2014 10:05 pm
Does anyone have an original hazard switch and bracket for Z900 A4 with bracket and buzzer they want to sell?
Bike now finished what a joy!
#2 PostAuthor: z1bman » Thu May 29, 2014 10:36 pm
:lol: :lol: :lol:
Wayne1960
#3 PostAuthor: Wayne1960 » Fri May 30, 2014 5:04 am
You do
#4 PostAuthor: Pigford » Fri May 30, 2014 7:50 am
I've got a complete HAZARD switch c/w bracket - but they do go for strong money :|
Wayne1960
#5 PostAuthor: Wayne1960 » Fri May 30, 2014 8:19 am
I thought they might PM me please
wayno
#6 PostAuthor: wayno » Fri May 30, 2014 11:24 am
some on ebay.com not cheap tho
#7 PostAuthor: z1bman » Fri May 30, 2014 11:31 am
Charlie
#8 PostAuthor: Charlie » Fri May 30, 2014 5:28 pm
Wow, I am seriously pleased they are cheaper for the 650's !!
Wayne1960
#9 PostAuthor: Wayne1960 » Wed Jun 04, 2014 9:09 am
Finally got myself a hazard switch and ver nice to. I have connected it up and wanted to ask how it should operate.
I'm sure this is more common sense but keen for it to function properly.
What it does
Ignition off pull switch, nothing. Turn on indicator left or right, nothing!
Is this correct as I read somewhere it should work with ignition off.
Turn ignition on, pull switch, nothing, turn indicator on left or right and hazards flash hooray! But is this right or should they simply come on when you pull the switch?
Hope you guys can help.
steve bowdler
#10 PostAuthor: steve bowdler » Wed Jun 04, 2014 9:16 am
Hi before I removed mine from my Ltd they worked with ignition off and on , but only if I put either left/right indicator on . was'nt sure if this was right either !! :??
Wayne1960
#11 PostAuthor: Wayne1960 » Wed Jun 04, 2014 9:36 am
Steve
sound like much the same as mine but mine will not work without the ignition on so i'm guessing there must be a permanent feed somewhere.
I read that it should work with the ignition off and i also tried it in park but nothing.
#12 PostAuthor: z1bman » Wed Jun 04, 2014 11:42 am
they should only operate with the ignition switched of or in the park position
Wayne1960
#13 PostAuthor: Wayne1960 » Wed Jun 04, 2014 11:57 am
That's very strange then. i simply plugged the switch into the spare 3 way terminal block. all colors matching the wiring diagram.
Everything on the bike works as it should so why wouldn't this?
What to do?
wayno
#14 PostAuthor: wayno » Wed Jun 04, 2014 12:04 pm
Have you got the 2 relays connected.
#15 PostAuthor: z1bman » Wed Jun 04, 2014 12:04 pm
have you fitted a new after market wiring ? have you got the diode fitted into the relay i think its fitted between the brown wire & the relay
