Cam Cover Oil Leak
IrishKev
Cam Cover Oil Leak
#1 PostAuthor: IrishKev » Sun Jun 01, 2014 5:07 pm
Hi Guys
I have been working on my Z1A where i changed the the gasket between the cyclinder head and the cam cover. I just ran the bike down the road on a test run and when I got back I could see some oil leaking from under the cam cover. Can anyone tell me what the torque settings are for the cam cover bolts. I have hand tightened them but i am not sure that is enough. I am a bit heavy handed and so I am trying to avoide damaging and bolts by over tightening them. Would be a great help is someone could let me know.
Thanks Irishkev
#2 PostAuthor: z1bman » Sun Jun 01, 2014 6:29 pm
70 in-lbs
mick znone
#3 PostAuthor: mick znone » Sun Jun 01, 2014 7:21 pm
had this problem when i changed my gasket, i just tweaked each one in turn and it fixed it, never did use a wrench.
#4 PostAuthor: Pigford » Sun Jun 01, 2014 8:22 pm
They do "settle-down" after a few runs (hot/cold cycles) - and I just nip them by hand to avoid stripping them, also use a small 10mm spanner - less leverage :wink:
Garn 1
#5 PostAuthor: Garn 1 » Sun Jun 01, 2014 9:01 pm
IrishKev, as Z!Bman says 70 IN-Lbs is correct, before tensioning check the usual place for leaks ~ the rubber half-moons.
Also, check for hair-line cracks on the adjacent outside edge bolt supports.
I never use a torque wrench for 6mm bolts, just develop a feel with a small levered 10mm spanner, as Pigford & MikeZ!A suggests.
RegardZ.
IrishKev
#6 PostAuthor: IrishKev » Sun Jun 01, 2014 11:17 pm
Thank Guys
I am a little heavy handed, as I have strip the threads before that is why I am relucant to put a spanner to it but I will try and nip them, then I will use the troque just to confirm.
jimmock
#7 PostAuthor: jimmock » Sun Jun 01, 2014 11:25 pm
This is what I use............
1 inch drive ratchet with a 1 to 3/4 stepdown, onto a 3/4 to 1/2 stepdown, onto a 1/2 to 3/8 stepdown, onto a 3/8 to 1/4 stepdown, onto a 10mm single hex socket.
Hope I've been helpful.
Just remember....
"Jimmock's the name and solutions is my game".
Jimmock. :wnkr
I hate people I don't like !
Users browsing this forum: No registered users and 174 guests
