Carb overflows
Wayne1960
Carb overflows
#1 PostAuthor: Wayne1960 » Wed Jun 04, 2014 7:03 pm
How long should the carb overflow pipes be? I got some pipe from ZPower but it looks tight for length.
So ow long should they drop past the frame?
Bike now finished what a joy!
PAULJAC47
#2 PostAuthor: PAULJAC47 » Wed Jun 04, 2014 7:33 pm
Best to make em lower than engine,well away from exhausts..
#3 PostAuthor: z1bman » Wed Jun 04, 2014 7:44 pm
no 1 carb is has the longest & as you go through to no 4 they get shorter fit no 1 first & push it through the rubber strap that fits on the upper right side engine mount the down the back of the engine & cut the pipe about 50mm below the engine
Wayne1960
#4 PostAuthor: Wayne1960 » Thu Jun 05, 2014 5:39 am
Ok done that but they hang awfully close to the exhausts! Am I little too long still
They all pass through the rubber loop and hang between the swing arm and the engine.
Wayne1960
#5 PostAuthor: Wayne1960 » Fri Jun 06, 2014 8:40 pm
Still worried about where the pipes are hanging!
#6 PostAuthor: z1bman » Fri Jun 06, 2014 9:30 pm
its the battery overflow pipe that you need to worry about. fuel normally only leaks out of the overflow when the bike is stationary or the fuel is left on especially with old bikes no matter how clean you think your tank is micro particles will still get through the filters & cause the float needles not to seat & fuel level will rise & run out of the overflow pipes. if your battery is over filled with acid or your charging system is over charging the battery it will run through the overflow & ruin the chrome on your wheels & your exhaust system then you will feel sick :lar :lar :lar
Wayne1960
#7 PostAuthor: Wayne1960 » Sat Jun 07, 2014 12:40 am
Ok understood but what's the answer. I have cut the pipes 50mm below engine but they still can easily touch the exhaust the way they hang. Does that feel right?
000zeds
#8 PostAuthor: 000zeds » Sat Jun 07, 2014 6:27 am
Place them between swinging arm and back of engine
Zeds-R-Us
#9 PostAuthor: z1bman » Sat Jun 07, 2014 7:43 am
use an O ring & secure it to the lower frame cross member with a cable tie & run the overflow pipes through the O ring
nw66
#10 PostAuthor: nw66 » Sat Jun 07, 2014 9:23 am
x2 twozeds :D
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Wayne1960
#11 PostAuthor: Wayne1960 » Mon Jun 16, 2014 11:47 am
I need to check the carb floats, yes i should have done this off the bike! but i'm still learning from my mistakes.
i understand i need to use clear pipe from the carb drain plug. What do i use in the drain plug that i can connect the clear pipe to without petrol pouring out?
#12 PostAuthor: z1bman » Mon Jun 16, 2014 12:13 pm
i have the genuine tool you can borrow but i would require a refundable deposit & cost of postage on its safe return.or you can but this from z1 enterprises
http://www.z1enterprises.com/ItemDetail ... =ZSM01-208
genuine kawasaki tool
PAULJAC47
#13 PostAuthor: PAULJAC47 » Mon Jun 16, 2014 12:49 pm
Wayne1960 wrote:I need to check the carb floats, yes i should have done this off the bike! but i'm still learning from my mistakes.
You can make a manometer thats a cheapo version of the proper one Z1b man shows,go to your local aquatics they sell clear air tube,get an inline plastic coupler for the tube,screw it into the bottom of the float bowl and attach pipe,tape to side if bowl to see level...Paul j
Jay1969
#14 PostAuthor: Jay1969 » Mon Jun 16, 2014 3:04 pm
z1bman wrote:its the battery overflow pipe that you need to worry about. fuel normally only leaks out of the overflow when the bike is stationary or the fuel is left on especially with old bikes no matter how clean you think your tank is micro particles will still get through the filters & cause the float needles not to seat & fuel level will rise & run out of the overflow pipes. if your battery is over filled with acid or your charging system is over charging the battery it will run through the overflow & ruin the chrome on your wheels & your exhaust system then you will feel sick :lar :lar :lar
Wayne - to prevent you "feeling sick" as z1bman puts it, buy a gel battery!
http://www.motorcycleproducts.co.uk/bat ... 29726.html
they hold a much better charge (keep them on a trickle charger during when not riding) and have a better cranking power
than lead-acid batteries.
