forks.stansion replacement
keith mayall
#1 PostAuthor: keith mayall » Sun Jun 08, 2014 7:02 pm
me again,,ive got new stansions..[fork]..ive removed the oil the spring ..the allen key at the bottem just spins,,struggling now.advice please to remove stansions..z900 :oops: do I need a special tool
#2 PostAuthor: z1bman » Sun Jun 08, 2014 7:21 pm
there is a special tool but if you re assemble the forks & use a windy/air gun it should come out if you haven't got one your local car or bike garage will do it for you for a drink
#3 PostAuthor: Pigford » Sun Jun 08, 2014 7:25 pm
Whittle a point on the end of a broom handle - and whack it down (inside) the stanchion to hold the damper still - gives you a good chance :wink:
As mentioned, a windy gun usually works OK too :!:
keith mayall
#4 PostAuthor: keith mayall » Sun Jun 08, 2014 7:43 pm
z1bman wrote:there is a special tool but if you re assemble the forks & use a windy/air gun it should come out if you haven't got one your local car or bike garage will do it for you for a drink
..thanks,
#5 PostAuthor: Al » Sun Jun 08, 2014 8:07 pm
Apparently: "they are mothers' to work with"
coldsummer
#6 PostAuthor: coldsummer » Sun Jun 08, 2014 8:49 pm
I used a thin wooden baton, it worked fine.
CAT3
#7 PostAuthor: CAT3 » Sun Jun 08, 2014 9:21 pm
Keith, you have mail !
#8 PostAuthor: z1bman » Sun Jun 08, 2014 9:57 pm
dont forget to remove the damper valve's from the old fork tube as the new replacement tubes do not come with them fitted
number 27 & 28 & the parts above them in the oblong box in the exploded view have to be removed
Users browsing this forum: Bing [Bot] and 90 guests
