z750 motor
big green bus
z750 motor
#1 PostAuthor: big green bus » Sat Jul 12, 2014 3:34 pm
can anybody tell me which engine this is gpz750 r1 z750L4 or gpz750 a etc
KZ750EE141285
GIMPieZ650
#2 PostAuthor: GIMPieZ650 » Sat Jul 12, 2014 3:39 pm
As far as I know kz750EE means its a z750e engine, basically an over-bored late model z650 engine
#3 PostAuthor: ADRIAN H » Sat Jul 12, 2014 4:55 pm
Z750E - engine number -
link to frame / engine numbers -
http://zedder.com/msg1.htm#Kawasaki
big green bus
#4 PostAuthor: big green bus » Fri Jul 18, 2014 8:44 pm
the motor I have found out is an z750 L4 or a gpz750 A2 does anybody know any difference between those two? it has a auto advance on it and a cable clutch not a push rod (but this may have been changed at some point)
#5 PostAuthor: z1bman » Fri Jul 18, 2014 8:52 pm
zx750 a2 uses a timing disc z750 l4 uses mechanical advancer
coldsummer
#6 PostAuthor: coldsummer » Fri Jul 18, 2014 9:31 pm
I fucking love z1bman.
#7 PostAuthor: z1bman » Sat Jul 19, 2014 4:17 pm
engine no makes it a zx750 a2
Crofty
#8 PostAuthor: Crofty » Sat Jul 19, 2014 6:16 pm
GPZ had bigger combustion chamber, but higher crowned pistons to give same CR of 9.5:1,
GPZ had the hot cams (esp the A1,2 and 3 models, up 0.5mm on the twin shock GPZ and 1mm on the base 750.
As stated by Z1B man the ignition system differed.
The inlet tracts on the GPZ unitrack engines was also factory worked with mild porting job around the guides and valve seats.
Installed valve height on the GPZ was also larger due to the exhaust cam having a smaller base circle.
GPZ A1 was 85 to 87PS (depending on which market it was made for), the L3 was 80PS.
Final drive ratio was different, but internally the same.
Clutch release was different on the A models being on the clutch cover itself and not by pushrod through gear shaft from sprocket side.
My workshop manual does not go beyond A1/L3, but they will be close
big green bus
#9 PostAuthor: big green bus » Sun Jul 20, 2014 5:52 pm
thank you for the replies chaps :lol:
Users browsing this forum: No registered users and 153 guests
