Help me sort out my head?????
Hi,
I`ve got to strip the top end on my 81 GPZ1100 due to leaking
gaskets, what I`d like an opinion on is whether it is worth
spending the extra on a Comectic one piece head gasket or
just going for a standard gasket set, the engine is in standard
tune.
What do you reckon.
Allan
tune.
What do you reckon.
Allan
- london calling
- big green bus
- paul doran
Allan, not stealing your thread, and still on the topic, does anyone know, if I should use any gasket-goo, grease or some compound, when replacing an early Z1 head gasket with a full copper gasket. I usually just use moly grease.
Also, what do you fill the O-ring groove in the centre tunnel on heads with that particular groove. (eg Z1A.Z1B Z900-Z1000)
RegardZ.
RegardZ.
Hello Garn & SMR610, regarding the Copper head gasket, we use Gascacinch, we have used this for a few years now although last year we struggled to source this product and so resorted to other products with varying degrees of sucess but we have managed to get the Gascacinch back on the shelf and it is our preffered choice
http://www.debben.co.uk/acatalog/Click_here_to_view_race_spares_and_tools.html#a49
Regarding the Cometic gasket, there are 3 main reasons for choosing Cometic over std, the first and main reason is that it does away with the awfull O ring that sits around the camchain tunnel, this fits badly if from a pattern gasket set and is v. expensive if genuine, it also is normally the reason behind the leak in the first place due to the rubber becoming hard and brittle due to heat. The second advantage over stock is tht the gasket itself is made from a CFM20 compound that is impregnated with glue, when heat is applied to this gasket (when the engine is run) the gasket seals itself to both surfaces, this provides better sealing properties than the stock gasket, no doubt if this gasket technology was available to Kawasaki 30 years ago they would have used it. The other reason for Cometic over std is the price. We never use the O ring but I think it is getting on for over ?20, which makes the Cometic gasket a better propersition on price.
Regards, Steve
Regards, Steve
Users browsing this forum: No registered users and 107 guests
and will now try the cometic. That camchain tunnel 'O' ring has always left a bad taste regarding price.
