blowing fuses
- steve bowdler
- steve bowdler
Jon
Iain marshall
Take the bodywork and tank off, replace fuse with 1/4" nail turn ignition on and see where the smoke / heat comes from first! It could be high resistance on the wire that's doing it, even if the connectors look Ok if it's the original loom all the wires will probably be oxidising under the plastic. Otherwise as stated check headstock wiring especially the white ignition switch feed.
Iain marshall
You only need a 1/4 with a kawa they don't have such a good charging system as H**** s, 8mm is a bit over the top, you may even be able to go down to 6mm without blowing it!!!
I did that on a trident T150V of mine, worked a treat, it was a knackered zener doing it, unplugged zener, rode her home and replaced zener and bit of wire - no problems after that.:cool:
Users browsing this forum: Bing [Bot] and 91 guests
