alt starter needle roller bearing..
gordon62
#1 PostAuthor: gordon62 » Wed Jul 23, 2014 11:58 am
Hi,
I want to replace the needle roller bearing on the alternator shaft, part no 92046-033, apparently bearing K222620.. I have measure the one on my z1000, and it come in at 22 x 27 x 20, so which is correct?? the bearing K222620 is 22mm x 26mm x 20mm.....
Chris Riv
Bearings
#2 PostAuthor: Chris Riv » Wed Jul 23, 2014 7:44 pm
Gordon, there's 2 sizes of these, the larger being the latest. Obviously the bearing needs to suit the crank/gear combo you have on your machine so I guess if you measure your crank & starter gear bore, that will tell you which one you need..........
Cheers, Chris.
Users browsing this forum: No registered users and 152 guests
