WANTED, z1000J Mechanical advance mechanism and inner cover
GIMPieZ650
#1 PostAuthor: GIMPieZ650 » Mon Jul 28, 2014 2:14 pm
After a mechanical advance mechanism to fit to a gpz1100UT engine as I will be fitting a Dyna S system rather than the cdi ignition
Will need to be from a z1000J type engine, also need the inner cover.
Cheers Dan
#2 PostAuthor: Al » Mon Jul 28, 2014 9:53 pm
You need a z1000J type as the z1000 ones have a different advance range.
You also need a J type inner cover as you cant fit Dyna 'S' to the Unitrak inner cover.
GIMPieZ650
#3 PostAuthor: GIMPieZ650 » Tue Jul 29, 2014 12:22 pm
Cheers have updated the add
GIMPieZ650
#4 PostAuthor: GIMPieZ650 » Tue Jul 29, 2014 1:56 pm
Sorted for a mechanical advance now, just after the inner cover
