carbs
royboy
carbs
#1 PostAuthor: royboy » Mon Aug 25, 2014 1:08 pm
hi still having trouble as to dismantle carbs on 900 a4, as I want to check the needle position. how do you remove the shaft running inside the carbs, so I can remove the slides. thanks
Z1parR
#2 PostAuthor: Z1parR » Mon Aug 25, 2014 1:19 pm
Roy there are five 8mm headed M5 bolts holding the shaft .
Four are under each carb top holding the linkage to the shaft , the fifth holds the cable quadrant to the shaft , undo all five .
On the carb backplate between carbs 1 and 2 there is a Phillips screw holding a retainer in a rebated groove on the shaft , undo this screw .
With all six of these bolts removed the shaft will slide out giving you access to all the slides .
0172 . Geoff Parr
royboy
#3 PostAuthor: royboy » Mon Aug 25, 2014 3:36 pm
thanks z1parR will look at that,would you have some pic's or a web site to look at. thanks roy.
#4 PostAuthor: z1bman » Mon Aug 25, 2014 4:09 pm
royboy
#5 PostAuthor: royboy » Mon Aug 25, 2014 9:35 pm
thanks all
Users browsing this forum: No registered users and 155 guests
