fork oil for z1000a1
evans
#1 PostAuthor: evans » Sat Aug 30, 2014 4:36 pm
what weighting fork oil should I use for 1977 z1000A1 ?
Chris
#2 PostAuthor: z1bman » Sat Aug 30, 2014 8:51 pm
evans
#3 PostAuthor: evans » Sun Aug 31, 2014 8:44 am
thanks, I have some 15w but suppose that will make the damping heavier ??
#4 PostAuthor: z1bman » Sun Aug 31, 2014 9:26 am
you can use 15w if that is what you have
Z1parR
#5 PostAuthor: Z1parR » Sun Aug 31, 2014 10:01 am
Put 10W in my 900's forks after rebuild , a fortnight later drained it out and replaced with 15W , happier with it now .
0172 . Geoff Parr
freddyz1r
#6 PostAuthor: freddyz1r » Sun Aug 31, 2014 10:21 am
I always put a higher weight in 15w/20w instead of 10w. ( is that because I'm fat :?: :oops: :roll: )
Z1parR
#7 PostAuthor: Z1parR » Sun Aug 31, 2014 10:26 am
Yes :lol:
0172 . Geoff Parr
freddyz1r
#8 PostAuthor: freddyz1r » Sun Aug 31, 2014 10:45 am
Z1parR wrote:Yes :lol:
haven't you ever heard of 'sugar coating' :?:
(Ps if a lady ever says, "does my bum look big in this ?"
"No, you're arse always looks huge!"
Is not the correct response :wink:
Z1parR
#9 PostAuthor: Z1parR » Sun Aug 31, 2014 11:11 am
Hmmm , that could explain why i live on my own now :lol:
0172 . Geoff Parr
freddyz1r
#10 PostAuthor: freddyz1r » Sun Aug 31, 2014 11:25 am
Z1parR wrote:Hmmm , that could explain why i live on my own now :lol:
yeaah, geoff, but it's a lot quieter that way :wink: :lol:
evans
forks seals/forks plugs with recess
#11 PostAuthor: evans » Tue Sep 02, 2014 9:34 am
Thanks everyone.
There appears to be an additional plug under the actual top cap on each upper fork, with a recessed square locator to take a 1/4 inch extension bar, which is not mentioned in either the Clymer or the Haynes manuals. But how do you get that out ?? The upper forks are none standard as the take a air assisted mechanism for pumping up the forks and the top caps have holes in them which has allowed water in to the top of these plugs with the square recess, so are very rusted up. I clearly need to get these out in order to be able to fill with new fork oil.
Any input much appreciated.
Chris
Richard Q
#12 PostAuthor: Richard Q » Tue Sep 02, 2014 10:11 am
"OMG!! that would look big in field full of Hippos," is also not a good response. My sister is still not talking to me :shock:
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
freddyz1r
Re: forks seals/forks plugs with recess
#13 PostAuthor: freddyz1r » Tue Sep 02, 2014 10:38 am
evans wrote:Thanks everyone.
Hi chris, I've not seen the 1/4" plugs :?: , but I've taken out several 1/2" plugs( I think the
1/2" ratchet end is what I've used :?: ) BE CAREFUL, the plug is under 'load',i. e. the fork spring is compressed under it.
if it's the same as I've done you simply undo the plugs with the ratchet, they are essentially a 'bolt' (threaded).
Hope that helps, cheers freddy
evans
#14 PostAuthor: evans » Tue Sep 02, 2014 11:01 am
Freddy many thanks. They are indeed 1/2 inch ratchet bar ends and badly ceased due to the holes in the caps letting in water. I have soaked them with a depth of WD40.
Not sure why they are mentioned in the manuals though ?
Chris
evans
#15 PostAuthor: evans » Tue Sep 02, 2014 2:22 pm
Also do you need a special tool to compress the fork springs when try to reassemble ?
