Z1000H carb conversion
Jerry
President
President
#1 PostAuthor: Jerry » Wed Sep 27, 2006 3:24 pm
Any tips or advice on converting a Z1000H to carbs. I've given some advice,but I've never done the job. Are Z1000J CV carbs the easiest way to go?
ash
#2 PostAuthor: ash » Wed Sep 27, 2006 8:13 pm
Jerry you should be able to put a1 or 2 carbs on and just blank out the inlets where the injectors are,
Iain marshall
#3 PostAuthor: Iain marshall » Thu Sep 28, 2006 4:59 pm
Jerry havent done anything with the early injection models(H G B1)but have heard its straight forward,remember some one saying there could be problems with low speed running due to the longer inlet tract??heres a pic(as usual)of a B1 thats been converted to CV carbs
big green bus
#4 PostAuthor: big green bus » Thu Sep 28, 2006 5:10 pm
i put z1000j carb's on a few B1's and all ran fine, (dyna jet kit on) just like B1 in the pic
#5 PostAuthor: Rich » Thu Sep 28, 2006 6:05 pm
Match the carbs to your inlet tract diameter - unless you're going to flow it as well.
london calling
#6 PostAuthor: london calling » Thu Sep 28, 2006 8:26 pm
What about a set of MK 2 Z1000 28mm carbs??
