Camshaft / shim gaps, noisy?
- warren3200gt
Hi Guys,
76 A4, I've got what sounds like a top end rattle. Cam cover off and jockey wheel seems to be fine. Checked the shim gaps and no 3 cylinder seems to be way out. The gaps should be between 2 and 4 thou, right?
Inlet cam, 1 = 2.5, 2 = 2.5, 3 = 5.5 and 4 = 2.
Outlet cam, 1 = 3.5, 2 = 4, 3 = 5.5 and 4 = 4.5.
The noise definitely seems to be coming from cylinder/s 3 and/or 4.
Before I get to concerned, and while I'm waiting for shims and tool to arrive, just wondering how noticeable/audible that excessive amount of gap would be?
Thanks, Warren
Thanks, Warren
Yes, some are a bit on the wide side but probably not enough to rattle too much, that is more likely to be caused by a loose cam chain. Is it a tic tic or a rattling noise? Have you checked the adjustment, have you got an auto tensioner or manual? Adjust according to the manual.
If you are a member of the OC, Jerry can supply exchange shims. Don't forget to keep a chart of your gaps and shims so you know where you are.
HTH
HTH
If at first you don't succeed, try and try again. Then quit. There's no point in being a damn fool about it.
W C Fields
W C Fields
- warren3200gt
- warren3200gt
- warren3200gt
https://www.hightail.com/download/UlRUR ... OFJYd3NUQw
30 second video download of engine noise.
I've done the shims and as you can hear the noise is still there. It does sound a lot worse on the video than it does in real life.
The up side is throttle response is better with the correct gaps!
- warren3200gt
- warren3200gt
Have you isolated which valve / area (screwdriver to ear method works well) is causing the issue?
Take the cam cover off then take the cam out then pull the bucket out to make sure is not sticking / broken / doggy shim / missing valve collet and try an see if there is a broken valve spring before stripping.
It may be that a valve guide has cracked / failed.
If you can not isolate it then stripping may still be a stab in the dark but it sounds like you will have no other option.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
zpower wrote:Have you isolated which valve / area (screwdriver to ear method works well) is causing the issue?
If a bucket was sticking it would misfire on that particular cylinder wouldn't it, which it is not doing.
- warren3200gt
Took the cam cover off again today. Checked the torque on every nut and bolt I could find. Couldn't find any play in any cams / carriers. All the buckets moved nice and freely. Gaps are now correct. Put it all back together, took out the tacho drive, started it up and depressingly the noise is still there. Risked letting it run for several minutes whilst having a good listen and search around. It's definitely coming from the front right side but I couldn't pin point it with the ear to a screw driver method despite putting it to every surface that has something moving beneath it. I'm not convinced its valves or guides after listening to them. It isn't chain related. It isn't bore related. Its not a rumble and I couldn't find any play so I doubt its cam bearings but as they are cheap I guess it wouldn't hurt.
It is certainly more evident on over run.
Users browsing this forum: No registered users and 88 guests
