Split base gasket
Split base gasket
Hi, After installing my base gasket and getting 2 pistons into the barrels i've noticed a split in my base gasket
. It's gone through half the width of the gasket only in line with the centre of one cylinder. What do you reckon, does it need replacing or should i use a bit of gasket glue?
ninjajen900
a new gasket.
later
