Smoke on startup.
shep65
Smoke on startup.
#1 PostAuthor: shep65 » Mon Oct 06, 2014 2:49 pm
Z1b that's been standing for a few years, recently got it back on the road but on start up 1&2 smoke real bad.
I'm pretty sure it's oil rather than fuel and it clears within about half a mile and stays clear until next ride.
I was thinking valve stem seals as I guess if worn bores/stuck rings it would do it all the time.
Any advice greatly appreciated.
#2 PostAuthor: z1bman » Mon Oct 06, 2014 3:02 pm
most likely valve seals
shep65
#3 PostAuthor: shep65 » Mon Oct 06, 2014 3:09 pm
Cheers,
Apart from the oil loss factor will leaving it do any damage?
Much of a job to do?
Thanks for qucik reply.
#4 PostAuthor: z1bman » Mon Oct 06, 2014 3:14 pm
it wont damage the motor as long as you keep your eye on the oil level. its not a big job but you will need a valve spring compressor
PAULJAC47
#5 PostAuthor: PAULJAC47 » Mon Oct 06, 2014 3:17 pm
Hi shep x2, stem seals,wont do any harm easyish job,but you need the tools,i would use gen Kwak or Viton seals,dont bother with owt else,i am in Wolverhampton if need any help/advice send me a Pm if you do..PaulJ
shep65
#6 PostAuthor: shep65 » Mon Oct 06, 2014 3:39 pm
Thanks for all the advice, I might take you up on that Paul.
jimmock
#7 PostAuthor: jimmock » Mon Oct 06, 2014 4:17 pm
I'd say valve stem oil seals too.
The only problem I'd say is (depending on the exhaust) blueing of headers on 1 and 2.
Jimmock. :wnkr
I hate people I don't like !
shep65
#8 PostAuthor: shep65 » Mon Oct 06, 2014 5:52 pm
jimmock wrote:I'd say valve stem oil seals too.
Standards, I'll keep an eye on them.
I may look into it over winter as the rest is pretty tidy so would like to get it as good as possible.
Thanks again.
jimmock
#9 PostAuthor: jimmock » Mon Oct 06, 2014 6:57 pm
Thanks again.
Double skinned headers will be OK.
Jimmock. :wnkr
#10 PostAuthor: chrisu » Mon Oct 06, 2014 7:30 pm
Thanks again.
Viton seals and less than a days labour to do it.
