Z1 exhausts
sprint
Z1 exhausts
#1 PostAuthor: sprint » Sun Oct 19, 2014 1:23 pm
Were the original Z1 4 into 4 exhausts of the double skinned type?
It seems like all the current replacements, Doremi etc are only single skinned? Does this mean that you are likely to end up with the header/downpipes discoloring?
jimmock
#2 PostAuthor: jimmock » Sun Oct 19, 2014 2:28 pm
YES to both.
Jimmock. :wnkr
I hate people I don't like !
Richard Q
#3 PostAuthor: Richard Q » Sun Oct 19, 2014 2:38 pm
The main reason for the discolouring is running the carbs too lean.
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
zedward
#4 PostAuthor: zedward » Sun Oct 19, 2014 3:18 pm
jimmock wrote:YES to both.
+1
Getting the correct set up. Timing, fuel,air etc preferably by a reputanle tuner on a dyno will sought out that problem
#5 PostAuthor: ZedHead » Mon Oct 20, 2014 9:02 am
Best ask the guys who have bought Doremi pipes off me, there are quite a few on here :D
As already said route cause of bluing is set up.
jimmock
#6 PostAuthor: jimmock » Mon Oct 20, 2014 12:06 pm
ZedHead wrote:Best ask the guys who have bought Doremi pipes off me, there are quite a few on here :D
I agree absolutely.
The single skin headers can help to pinpoint an issue.
Jimmock. :wnkr
RAYZ1
#7 PostAuthor: RAYZ1 » Mon Oct 20, 2014 9:40 pm
Don't let a garage set up your carbs unless your e there, shut off the engine after a couple of minutes and cool, also tip from the classic car community, flood the internals of the pipes with well used engine oil and drain out surplus. I did both of the above and pipes are perfect. Oil burns off and leaves a protective coat, I also bought .2 tins of heat dispersant paint and emptied them down the headers and let dry before doing the oil. doing nothing will probably result in some form of yellow or bluing , if it doesn't that's good but I wouldn't take the risk
