hello gents is there any way to tell externally if a bike has a big bore engine kit on or do they use the origional block now been told my gpz1100a1 has a cosworth big bore kit on or is the bloke talking out of his arse.
many thanks in advance john
big bore engine
- london calling
Often the 1100 cylinders are bored out to give 1170cc,which is 75mm.
The 1089 block can be taken out to 1170 without the need for liners.
Any larger and you need liners and the crankcases opening out.
This would not be visible externally and as Piggy says a big bore block usually has the makers name cast into it,such as Wiseco,MTC,etc
Jack
neilbarrett
- ZedHead
big bore engine
If it eats starter motors could be a 1260, people often forget over the years, they just know cozzy or wizzie, what colour are the gaskets that's if they're clean, you know rocker,head,base(bottom of barrels) if they're red it's a wiseco.
More Smiles Per Mile
Users browsing this forum: No registered users and 93 guests
