Sorry Karen,
I have taken the family to blackpool for the weekend before the half term madness - last weekend of the month are nearly always busy for me personally
Midz Meet Oct
Midz Meet Oct
- paul doran
It was a good run out - took the scenic route there & back through Newbold Verdon & Market Bosworth.
Keith - Yes it was the look I was after- I got the bracket you supplied powder coated and it looks brand new. I spent quite a long time choosing the right shaped lights (Similar to original oblongs but smaller)
Although the bracket 'fits' - the rear indicator stems interfere with the Z1R tailpiece so I had to use slightly longer bolts (Only about 5mm) so the rear light sits very slightly further back - existing wiring accommodated the move & I don't think it shows.
The front ones fitted easier but I had to cannibalise some old indicators that over the years I had smashed in various escapades - but I needed the right shaped bits that fit in the lug to attach the stem.
Anyhow after a day or two of head scratching it all went together ok - and I can revert to standard if I want!
010
