gpz1100b1
- big green bus
gpz1100b1
has anybody got a wiring diagram or help me with the wiring on my B1 I want to fit the side stand cut out, but cannot find any where to plug it in and cannot find anything in the work shop manual I also have a rubber black box that fits between the ignition pickups with two other wires coming out and cannot find where they go too
I have sent you Kawasaki service manual KZ1000, KZ1100 with GPZ1100B1 Suppliment) to your email, via a Dropsend link. As the File is 48mb.
Hope this helps.
Hope this helps.
- sockpuppet
Has the sidestand switch got 2 wires , or 4 ?
Just wondering if its the same as a B2 .
Both my B2`s have 4 wires -- Bullet connectors one pink male one and 3
female- -
even though the wiring diagram in my manual shows just a green and
brown!!
3 of them -- (pink and 2 black) plug into a small sub harness about 3" long
with a block type connector on , which plugs into a block connector that
comes out of the harness under the tank , the remaining one plugs into a
bullet connector alongside .
Regards
Mick
female- -
brown!!
Regards
Mick
- big green bus
- sockpuppet
- big green bus
This may help [ or not !]
My 1100 shaft has a four wire harness from the side stand switch.
1 pink, 1 blue/white and 2 black
All end in separate bullet connectors, joining identical colour wires in the main harness under the fuel tank by the left hand top tube.
UK model with a cut out switch on the l/h switchgear.
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
Outlaw Josey Wales
Member No. 555
- big green bus
doebag wrote:This may help [ or not !]
yes those are the ones I must have the wrong L/H switch
- big green bus
and what is this ?
[img][img]http://i150.photobucket.com/albums/s82/worringtonminge/Photo0609_zpsdc0aa68f.jpg[/img]
[/img]
[/img]
- big green bus
- sockpuppet
Are you having injection or carbs ?
If you`re using carbs this bit can be left out and the pickup plug and igniter plug fitted directly together .
( I have one of these in the box of bits i have from when i converted mine 20 odd years ago so i`m guessing the 2 wires go to something to do with the injection system that needs a feed from the ignition circuit !)
Regards Mick
Regards Mick
- big green bus
Users browsing this forum: No registered users and 117 guests
