Shim sizes
FOZ1A
Shim sizes
#1 PostAuthor: FOZ1A » Tue Nov 11, 2014 11:51 am
During the winter motor rebuild, I am going to fit a set of cams with a valve lift of .395, duration of 284. Currently the shims are all between 250/260 - what shim sizes do I need to drop down to?
foz
Jeff Saunders
#2 PostAuthor: Jeff Saunders » Tue Nov 11, 2014 12:07 pm
Unless the base circle of the cam is different (which is shouldn't be), you shouldn't need to change shims. The reality is you might need to tweak the clearance a little as manufacturing tolerances can vary a little between cams.
