Bolts
Pinhead
Bolts
#1 PostAuthor: Pinhead » Wed Dec 03, 2014 9:07 pm
Hi all
Is there a diagram to show the size and where they go in the
Engine casings
As I have taken off the sump and can't remmber which go's where
[/list]
#2 PostAuthor: ADRIAN H » Wed Dec 03, 2014 9:11 pm
Pinhead
#3 PostAuthor: Pinhead » Fri Dec 19, 2014 8:12 pm
Hi
I have had a look and I can't work it out the diagram
I have 1 long bolt 3 a bit shorter and the rest are shorter
Is there a diagram for idiots
Pin
Richard Q
#4 PostAuthor: Richard Q » Fri Dec 19, 2014 9:35 pm
The long one goes into the hole with the boss - it's near the middle on the front. Just start putting the smaller ones in, and if they bottom out straight away, use the next size up. The parts manual does have a diagram in it.
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
#5 PostAuthor: z1bman » Fri Dec 19, 2014 9:51 pm
