Air box parts
Richard Q
Air box parts
#1 PostAuthor: Richard Q » Thu Jan 01, 2015 11:31 pm
I've been trying to refit my air box and battery carrier on my Z900 A4 and have found I am missing a few bits, quite a few bits actually.
Anyone got :-
1/. Air box breather pipe 92059-124
2/. Air cleaner stay 32105-006
3/. Air cleaner cap 11012-070
4/. Inlet pipe holder 11040-001
5/. The left and right hand plate the above fixes to - 11040-002, and 11040-003
6/. Two of the damper rubbers for the battery case 92075-076, and two of the metal tubes/collars that go with them 92027-129.
Richard
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
#2 PostAuthor: z1bman » Fri Jan 02, 2015 6:43 pm
Bill Newman
#3 PostAuthor: Bill Newman » Fri Jan 02, 2015 10:21 pm
Hi Richard - when I did my KZ900 I had the same problem with airbox parts. The breather pipe is like hens teeth and expensive - here is an original:
http://www.ebay.co.uk/itm/KAWASAKI-NOS- ... 0688034198
but Taner at Z1Parts.net does a decent replica here:
http://www.ebay.co.uk/itm/200574380756? ... EBIDX%3AIT
Re the Air box cover, I may have one in the garage loft - I will have to get up there next week to put the Christmas decorations away and will have a look for you if you have not been sorted by then.
Richard Q
#4 PostAuthor: Richard Q » Fri Jan 02, 2015 11:52 pm
Thank you Z1Bman, and Bill.
I have managed to find a UK supplier for the smaller bits, but the inlet pipe holder and the two plates they fix into seem to be made of unobtainium. I suppose I was hoping someone had all of it after converting to some other intake system.
Cheers anyway
Richard
1976 KZ900
