its got me pulling my hair out.
Farmer wrote:The 4 air/fuel mixture screws are set at 2 1/2 turns out and look the same, so far I have only disassembled 1 carb at a time with those screws out I do spray carb cleaner through then air line it, I have bench sync the carbs and done the float level at 22mm, the o rings are I think the drain screw, the filter where the float needle sits, I can`t remember the other 2, I have seen a mikuni carb jet cleaner tool also from America rather like the gas torch type, is it worth getting one ?.
I have not checked carb inlet rubbers and its on original air box but the airbox to carb rubbers are not connected yet.
