Rear brake pedal spring--mystery
steve rees
#1 PostAuthor: steve rees » Wed Jan 02, 2008 8:51 pm
Guys,
I need some help here!!!
I have just about finished my Z1000 Ltd which is being rebuilt back as a Z1000 but i have a problem with the rear brake pedal spring.
the standard listed spring which wraps around the pedal just does not work at all--this is because the brake pedal mounting bracket and spindle is mounted on the footrest hanger A frame bottom tube where as the standard Z1000 bracket is mounted on the main frame diagonal tube--hence the point where the spring starts to produce tension is in a different place and does not work.
Anyone got a solution?????????
or any one got a part number for a Z1000 Ltd spring
all help much appreciated
Regards
Steve
Reecy m21
london calling
#2 PostAuthor: london calling » Wed Jan 02, 2008 9:26 pm
Which model LTD is it Steve??
I've got a parts book for the 1981-1982 Z1000 LTD (K)
Jack
steve rees
its a 1978 Z1000b2
#3 PostAuthor: steve rees » Wed Jan 02, 2008 10:28 pm
London,
Mines a 1978 B2 model
great if you can help
regards
steve
Reecy m21
steve f
#4 PostAuthor: steve f » Thu Jan 03, 2008 8:40 am
i had this with a kh500 i bought in bits built it all up nothing missing but the rear brake pedal spring didnt fit or work then i realised it fitted from the back of the frame on the pivot arm and not on the pedal like most other triples worth a try
bedlow1
#5 PostAuthor: bedlow1 » Thu Jan 03, 2008 8:42 am
here you go 78 z1000ltd b2
item 22 is part no 43005-041
1972 Z1 Euro Spec
1975 Z1B UK Bike
steve rees
Problem solved
#6 PostAuthor: steve rees » Fri Jan 04, 2008 4:03 pm
Thanks for your help lads--problem now solved
It turns out that the KZ1000B2 has a Z900 frame and brake pedal mounting brackets but a pedal only used on the B1/B2 Ltd's different to the A1/A2 series.
flew across to J Browse in Wrexham and got a used one this morning now all will work.
Thanks again
Steve
Reecy m21
