gpz 750 r1 forks
gpz 750 r1 forks
What psi are my forks supposed to be filled at. The table on the pdf manual has a part missing. Any help would be appreciated thanks
I'd get this double checked
but I think 10psi is the max. I was putting in my gt.
the seals can blow from about 15psi
Blow them up with a pushbike pump or similar NOT COMPRESSOR, (they fill very quickly
Cheerz freddy
Cheerz freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
freddyz1r wrote:I'd get this double checkedbut I think 10psi is the max. I was putting in my gt.
the seals can blow from about 15psi![]()
Blow them up with a pushbike pump or similar NOT COMPRESSOR, (they fill very quickly)
Cheerz freddy
Cheers for that Freddy. I can see that bit on the manual but it said another number on the pdf that was cut off. I will put 10 in and see what happens.I will use a bike pump too
