meter bracket foam
Richard Q
meter bracket foam
#1 PostAuthor: Richard Q » Wed Feb 11, 2015 8:59 pm
When removing the clocks from their bracket, I noticed the remainder of a foam gasket material, some stuck the bracket, some to the clocks.
I take it is was there for damping, so I was going to replace it. Thing is though, I have no idea how thick it should be.
Any help ? :D :D
I have some 3.5mm thick self adhesive foam, and some 10mm.
Richard
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
mick znone
#2 PostAuthor: mick znone » Wed Feb 11, 2015 10:13 pm
TLC made some of these a few years back, great they were, i recall them being about 4mm.
tlc
#3 PostAuthor: tlc » Thu Feb 12, 2015 8:14 am
The foam is called Toshiba and it is 6mm thick.
I bought some thinner foam recently from ebay which was the same.
http://pages.ebay.com/link/?nav=item.vi ... 1338185781
Richard Q
#4 PostAuthor: Richard Q » Thu Feb 12, 2015 10:03 am
Cheers chaps :D
I think I'll just double up the stuff I have and use 7mm then. 1mm wont make any difference and its quite soft anyway. It's close cell as well so won't hold any water.
Richard
1976 KZ900
