Z1-R Clock Mounting Dampers**Solution Now Found + pics**
pertonpc
#1 PostAuthor: pertonpc » Mon Feb 16, 2015 8:02 pm
Hi People
Stripped my clock bracket today and the foams were knackered - bit like stale sponge cake but harder to scrape off :cry: :cry:
I have some foam I am planning to trim to shape - but does anyone know where I can get either of the foams from as a spare part :?:
Listed as item 6 & 9 on this diagram -
part code is 92075-1050 large and 92075-1051 small
Also does anyone have any successful ways of doing this with a Z1-R bracket?
Not sure whether best results will be to stick a strip around top of clock then insert into bracket, or stick a strip round top inner face of bracket and drop the clock into it.
Anyone got any experience or pics of a home made set?
There is one on eBay at the moment - http://www.ebay.co.uk/itm/like/12153218 ... 0&ff14=108
Thanks for looking. From Mark
#2 PostAuthor: ADRIAN H » Mon Feb 16, 2015 8:21 pm
One of the larger ones on ebay, a bit pricey
http://www.ebay.co.uk/itm/NOS-Genuine-K ... 1532184356
#3 PostAuthor: ADRIAN H » Mon Feb 16, 2015 8:26 pm
You could try Neoprene rubber strips selff adhesive - but would nt know what thickness or width you would need ?
http://www.ebay.co.uk/sch/m.html?_odkw= ... e&_sacat=0
KeithZ1R
#4 PostAuthor: KeithZ1R » Mon Feb 16, 2015 8:27 pm
Talk to Compo Mark :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
pertonpc
#5 PostAuthor: pertonpc » Mon Feb 16, 2015 8:37 pm
Thanks Guys
I will send Compo a message Keith cheers.
p.s. got my forks serviced now - thanks for the oil info :lol:
Just waiting for the new paint on the bracket to harden off before I have an attempt at making a foam -
RGH
#6 PostAuthor: RGH » Mon Feb 16, 2015 8:44 pm
Give Jimbo an Email at Redline, his stock is constantly changing and some times doesn't list the parts he has.
Do you need this bit? Scrowl down.
http://www.redlinecycle.com/Z1-R%20Dash%20Panel.html
compo z1r
#7 PostAuthor: compo z1r » Mon Feb 16, 2015 9:07 pm
mark you've a pm
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r
#8 PostAuthor: compo z1r » Mon Feb 16, 2015 9:36 pm
clock damper
pertonpc
#9 PostAuthor: pertonpc » Mon Feb 16, 2015 10:04 pm
Cheers Neil
One set of those will do perfectly thanks.
You have a pm and some PayPal funds.
Thanks for your trouble.
From Mark
compo z1r
#10 PostAuthor: compo z1r » Thu Feb 19, 2015 7:07 pm
pertonpc wrote:Cheers Neil
From Mark
NOW COMPLETE mark posting Friday morn :wink: :wink:
pertonpc
#11 PostAuthor: pertonpc » Thu Feb 19, 2015 9:57 pm
Cheers Neil,
Will put some pics up when I get them.
Have checked the meter harness today - all wiring seems fine.
Likewise for the ammeter and fuel gauge fuse unit.
So I can get the clocks rebuilt when your dampers arrive. :lol:
pertonpc
#12 PostAuthor: pertonpc » Sun Feb 22, 2015 7:52 pm
The new Z1-R silicon meter dampers have arrived now. Many thanks to Compo Z1-R who has made them for me.
They are a perfect fit for the standard bracket and even have a slot for the rolled edge of the bracket to go into. No sticky tape or glue needed :clap:
All these other dampers have to be fitted onto the bracket as well -
Here's what the rebuilt meter bracket looks like now.
I have done a test fitting back onto the bike to make sure I can find and refit all the right fasteners and components. It seems to make more sense now than when it was dismantled - because I have found out what all the pieces do and how they link together.
KeithZ1R
#13 PostAuthor: KeithZ1R » Mon Feb 23, 2015 12:55 pm
Not as shiny but you get the Idea :D All five now have this system and I have a spare set :hon
Keith
:bop :gom
mistaken.
DavidZ1R
#14 PostAuthor: DavidZ1R » Mon Feb 23, 2015 6:14 pm
Oh yes put mine on this weekend, just the job :D
Users browsing this forum: Bing [Bot] and 222 guests
