Wiring A4
Wiring A4
I put the battrey back on today after nearly getting to the end of a strip and rebuild
The high beam light is on as the neutral light
The neutral come on if you use the pass button
The oil light does not come on
All the other bit seem to be working ok
I hate wiring
As far as I can see all the wires are in the right places I did a A to B sticker on all the ends
The only thing different is I have used new switchs
Any help
I hate wiring
Any help
- z1000puddin
- z1000puddin
I think you asked me a while back about restoring your switches, so if you still have them? Open up the head light, disconnect the replica ones, and plug in the old ones, ( if they worked before the rebuild ) and see if the problem is fixed.. If those new switches was the problem, You can send to me your old ones for refurb, or I might have a set already done? And could do you a part-ex on your old set.. ( Quickest way ) and you can send the new ones back for a refund.. Zed man ( switch guy )
Just a update
Oil pressure switch buggered / ordered a new one
Going to swop the neutral and high beem / easy one to do
Tried the old switches but the lights still don't work with either must be something I have done
End on a good note / it started up and sounds really good
Pin
Pin
- Ginger Bear
Pinhead wrote:I love my z900
Went out to fix the wiring and
It fixed it self it all working ok now
Am I fooling myself
Probably, end up with an intermittent fault. Sorry.
Users browsing this forum: zed9 and 72 guests
