Z1100R loom question.
tlc
#1 PostAuthor: tlc » Fri Feb 20, 2015 7:02 pm
Asphalt Cowboy is coming on apace with the finishing line well within sight. I have though a question on loom connections.
On the battery negative loom there is a small 8 amp wire with a 6mm ring connector that obviously connects to the frame somewhere. Also out of the main loom there is a similar connector which emerges just under the headstock.
Any suggestions as to where on the frame these should be connected?
Ta muchly.
Users browsing this forum: zed9 and 67 guests
