GPZ1100B2 rebuild cellar find
1962royp
#1 PostAuthor: 1962royp » Mon Mar 02, 2015 9:15 pm
[urlhttp://i.ebayimg.com/00/s/NzY4WDEwMjQ=/z/OIcAAOxyNa9SKC6U/$(KGrHqZ,!qYFIOK-R0LRBSKC6Tw)5Q~~60_57.JPG]
Guys how would i test this to see if it works and what does it do i cannot find it in my manual?
I know the ignition pick ups run through it with two extra wires but thats it[/url]
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
1962royp
#2 PostAuthor: 1962royp » Mon Mar 02, 2015 9:18 pm
might be better if i give you the ebay number
400567195787
Try it this way
GPZ1100 B2 owner
GPz 305 project
1981 KZ1000 LTD
Z1parR
#3 PostAuthor: Z1parR » Mon Mar 02, 2015 9:22 pm
0172 . Geoff Parr
#4 PostAuthor: z1bman » Mon Mar 02, 2015 9:24 pm
it is the side stand warning relay
1962royp
#5 PostAuthor: 1962royp » Mon Mar 02, 2015 9:25 pm
Thats the one.
Tell you where i am it runs if i sray fuel in the air box but i have no injectors.
I have tried the test as in the manual but it only sends power to the injector wires when it fires up and not when cranking ?
I have a problem with the side stand cut out as its broken would this be my problem or does this relay send signals to any where.
GPZ1100 B2 owner
GPz 305 project
1981 KZ1000 LTD
#6 PostAuthor: z1bman » Mon Mar 02, 2015 9:42 pm
you can remove the relay from the cdi & fit the cdi block connector to the other block connector left vacant from removing the relay but it doesn't have anything to do with the injectors firing
you problem is more than likely this fuel injection relay
1962royp
#7 PostAuthor: 1962royp » Tue Mar 03, 2015 8:22 am
I thought the relay but after testing it it all seems to do what it should it feeds the fuel pump too.
Has any one got one to sell or even borrow to try.
I have checked kawasaki no longer available.
I think there will be a couple of std relays i could use instead ands link them.
I think i should ring an electrician of mine.
GPZ1100 B2 owner
GPz 305 project
1981 KZ1000 LTD
gpzer
Re: GPZ1100B2 rebuild cellar find
#8 PostAuthor: gpzer » Tue Mar 03, 2015 3:08 pm
hi roy ,might be worth ringing john browse(j browse motorcycles) of wrexham tel 01978 355556 he seems to have a lot of the rarer b2 parts for sale .hope that helps :)
GPZ1100 B2 OWNER
1962royp
#9 PostAuthor: 1962royp » Tue Mar 03, 2015 3:14 pm
Thanks for this.
I have spoke to my old apprentice this morning who is a whizz with anything electric on vehicles he tells me he can make one of these with the diagram from the book its just two relays wired together apparently so i will give him ago.
They are £80 new.
Im trying to aquire a side stand lock out switch as mine was in a bad way i think this might not be helping things.
New battery has arrived today so we are getting there.
Thanks for the advise.
GPZ1100 B2 owner
GPz 305 project
1981 KZ1000 LTD
