Sean.
Speedo and Rev counter Mounting
Hi all, can anyone tell me if the Foam/Rubber that the clocks are mounted on is available if not what can I use for this job. I took the rev counter off to change the bulbs and the foam turned to dust, so now they are both a bit loose. Thanks.
Sean.
Sean.
- DogsbolloxofZ1B
Sean,
You occasionally see the die-cut ones for sale on the ebay.com site but to be honest almost all of the ones I have bought are incorrectly cut so you end-up trimming them. I use a 5mm packaging foam fairly 'close' cell that comes with a lot of packaging these days. Does the job just cut to size & stick it down.
Mike
Mike
Users browsing this forum: zapo and 73 guests
