Dyna S Coils
fusionpaul
Dyna S Coils
#1 PostAuthor: fusionpaul » Sat Mar 14, 2015 3:54 pm
Just wondering if anyones got any pics of dyna coils mounted ? Just tried to fit some green coils & having real issues with the clearance for the plug leads ? can't seem to mount them any other way than with the leads pointing towards the rear of the bike & upwards ??
#2 PostAuthor: Ginger Bear » Sat Mar 14, 2015 4:09 pm
My old Z1000. leads pointing forwards. :??
Low voltage connection is very close to mounting pillar. Heat shrink is a simple solution. On my latest project I have used nylon bar, drilled to fit over the 6mm mounting bolt.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sat Mar 14, 2015 4:31 pm
HT leads should face forward and up as Steve's pic.
Steve,is that relay for the 'Wired George'mod good location if it is.
Regards
Steve
#4 PostAuthor: Ginger Bear » Sat Mar 14, 2015 6:19 pm
wilsonsjw11 wrote:Steve,is that relay for the 'Wired George'mod good location if it is.
It is indeed.
fusionpaul
#5 PostAuthor: fusionpaul » Sat Mar 14, 2015 7:14 pm
Ginger Bear wrote:My old Z1000. leads pointing forwards. :??
Thats great, just the info i need, much appreciated.
Garn 1
#6 PostAuthor: Garn 1 » Sat Mar 14, 2015 7:37 pm
I also found using Ginger's facing forward the best configuration, however, I utilise "Right-angle" connectors to reduce cable lengths.
RegardZ.
Mark Tiller
#7 PostAuthor: Mark Tiller » Sat Mar 14, 2015 8:06 pm
wilsonsjw11 wrote:HT leads should face forward and up as Steve's pic.
Regards
Steve
instructions say forward and up on a Kwak......down & rear on Suzis
07962421462
IanM63
#8 PostAuthor: IanM63 » Mon Mar 16, 2015 10:21 pm
Got me curious now... What on earth is the "wired George mod". :?:
#9 PostAuthor: z1bman » Mon Mar 16, 2015 10:40 pm
http://www.wgcarbs.com/index.php/using- ... s/89-coils
IanM63
#10 PostAuthor: IanM63 » Mon Mar 16, 2015 10:46 pm
Ok, thanks for that. :wink:
Garn 1
#11 PostAuthor: Garn 1 » Mon Mar 23, 2015 11:53 pm
To be complete, I just thought i'd mention, or rather illustrate, the right-angle connections I used with the Dyna Coils.
They must save about 75 mm of cable on each lead leg.
These right-angle rubber mounts were purchased already connected to the insulation lead. The actual insulated leads were labeled "BOSH Super Sports Induction Core 790" I'm not sure of the quality of these leads, I always use copper-core.
Further, you might see a small bracket (sheet-metal spacer) I made, to be able to use the longer mounting spacing of the Dyna coils and thus avoid the closeness of the primary connection.
This was not easy as the mount tended to throw the coils closer together in the front.
Image.
RegardZ.
