Brake light indicator 900 A4
Gavin
#1 PostAuthor: Gavin » Tue Mar 17, 2015 6:12 pm
Does the indicator,light up when the bulb fails or when the brake lever is pulled or pressed.?
Z1000 MK2
Z1300 DFI
#2 PostAuthor: z1bman » Tue Mar 17, 2015 6:32 pm
it lights up when you press the brake & it flashes when the bulb has gone or the outage relay goes duff
Gavin
#3 PostAuthor: Gavin » Wed Mar 18, 2015 7:27 pm
z1bman wrote:it lights up when you press the brake & it flashes when the bulb has gone or the outage relay goes duff
I have checked the bulb and that is OK the brake light works from front and rear levers.
To be honest i am not used to red lights coming on unless there is low oil so I am leaving as it is.
Z1000 MK2
Z1300 DFI
Z1parR
#4 PostAuthor: Z1parR » Wed Mar 18, 2015 8:38 pm
I would leave it too Gav .
A red light coming on the clocks at night will be like a poke in the eye .
0172 . Geoff Parr
Users browsing this forum: zapo and 75 guests
