engine finish
freddyz1r
engine finish
#1 PostAuthor: freddyz1r » Mon Mar 23, 2015 6:18 pm
Don't know if this should be here or 'discussion'? But I need a little help hence here it is :shock: if it needs to be moved, then please do so :up
The engine is a 1981 z1100st.
I have just taken my totally stripped engine down to the 'vapour blasters'.
he has given me 2 options:-
1, vapour blast = which will give me a 'polished' finish and will be no good for painting or lacquering.
2, bead blastered = a bit rougher, still an even smoothish finish, but ideal for painting or lacquering. He says it gives a good key.
Questions / Considerations:-
What was the original finish ? Bare ally, painted silver, lacquered or painted silver then lacquered ???
I want to ride the bike , not a show pony :roll: and I don't want to spend 'hours' polishing :oops:
I've never had a bare polished engine and it sounds like a lot of work later ?
I'm thinking painting or lacquering ?
What finish have you used ?
no pressure guys, but I've got to let him know by friday :oops:
thanks in advance, freddy :D
freddyz1r
PUM 329
baz
#2 PostAuthor: baz » Mon Mar 23, 2015 6:35 pm
why waste your money on either if your going to re paint it :?:
just have it dipped in an acid bath and away you go :D
neilbarrett
#3 PostAuthor: neilbarrett » Mon Mar 23, 2015 8:14 pm
get it powder coated
Gavin
#4 PostAuthor: Gavin » Mon Mar 23, 2015 8:16 pm
Original is Alloy finish. I had 2 of these.
Z1000 MK2
Z1300 DFI
Garn 1
#5 PostAuthor: Garn 1 » Tue Mar 24, 2015 12:12 am
I have seen a Z900-A4 painted and it has lasted for years. Don't know the name of the paint, however, it was hard to tell it wasn't alloy.
BTW. I've always left them alloy.
RegardZ
Re: engine finish
#6 PostAuthor: ADRIAN H » Tue Mar 24, 2015 10:55 am
Bare aluminium finish I believe is the standard.
If you ever want to revert back to standard - bead blasting is too aggressive.
I would vapour blast them and then etch prime before paint, so you can revert back if you wish ?
Depends what you want ?
Personally I would go for powder coating, talk to Nick at Griffs Powder coat, Bristol and ask what prep they do before powder coating.
Re: engine finish
#7 PostAuthor: chrisu » Tue Mar 24, 2015 1:13 pm
ADRIAN H wrote:Bare aluminium finish I believe is the standard.
^^^^ this
Gavin
Re: engine finish
#8 PostAuthor: Gavin » Tue Mar 24, 2015 1:24 pm
You will need to check if etch primer is heat resistant, i was told it wasn't.
Z1000 MK2
Z1300 DFI
Re: engine finish
#9 PostAuthor: ADRIAN H » Tue Mar 24, 2015 2:03 pm
I have used Heat resistant etching primer in the past on a DT400 engine. They may not make it anymore ! I think manufacturer was Metacote, I will have to have a look and see if I have any left ?
Users browsing this forum: zapo and 75 guests
