Spark
jez1100r
Spark
#1 PostAuthor: jez1100r » Sat Mar 28, 2015 12:42 pm
When I turn the ignition on I get a single spark from plug 1 and 4 .when turning over sometimes sparks sometimes not would this be pick ups or cool.?
#2 PostAuthor: ZedHead » Sat Mar 28, 2015 12:49 pm
What ignition are you using? Have you a good +12v feed to the coils and electronic ignition?
jez1100r
#3 PostAuthor: jez1100r » Sat Mar 28, 2015 12:59 pm
Standard ignition yes 12volt feed
1962royp
spark
#4 PostAuthor: 1962royp » Sat Mar 28, 2015 1:43 pm
its not the side stand cut out switch is it
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
#5 PostAuthor: ZedHead » Sat Mar 28, 2015 1:51 pm
Ok. So what are the symptoms? We need more to go on.
jez1100r
#6 PostAuthor: jez1100r » Sat Mar 28, 2015 1:51 pm
No switch long gone
jez1100r
#7 PostAuthor: jez1100r » Sat Mar 28, 2015 1:57 pm
I turn the ignition on and you get a single spark from 1 and 4 that is before I tuch the start button
#8 PostAuthor: ZedHead » Sat Mar 28, 2015 2:15 pm
Does the bike do anything when you press the start button? eg misfire. I would expect something if you have any sort of spark.
Gavin
#9 PostAuthor: Gavin » Sat Mar 28, 2015 2:59 pm
Check for corrosion on the 2 LT leads and coil terminals and check the HT leads for damage.
Z1000 MK2
Z1300 DFI
jez1100r
#10 PostAuthor: jez1100r » Sat Mar 28, 2015 3:17 pm
All plugs out at the moment was checking spark as bike will not start .fule going in exhaust and backfiring .that is when I saw the spark before touching start button
#11 PostAuthor: z1bman » Sat Mar 28, 2015 4:21 pm
have you done a resistance check on the pick up coils. have you tried swapping the ignition coils over ?
#12 PostAuthor: Pigford » Sat Mar 28, 2015 4:40 pm
Fit a NEW set of Denso plugs :wink:
jez1100r
#13 PostAuthor: jez1100r » Sat Mar 28, 2015 4:45 pm
How do you do a resistance check?
#14 PostAuthor: z1bman » Sat Mar 28, 2015 4:59 pm
check resistance between each pick up coil. resistance should be 360-540 ohms
jez1100r
#15 PostAuthor: jez1100r » Sat Mar 28, 2015 5:09 pm
Just swaped the coil wires round and the spark goes to 2and 3 not 1 and 4 without touching start button
Users browsing this forum: Bing [Bot] and 66 guests
