The bike.
Turbo dismantled
Will come back later with more info/pictures.
PS. Can i call it light????
Steve R wrote:There doesnt look much to a turbo does there I wonder why they are so expensive?
fastbyme wrote:shame its a B flow with ur kit ..F flow is a better upgrade ....u can swap compressor wheels to a f flow and put a . 60 turbine housing on and it will flow the same a ff 40 .....if u need any rajay bits think ive still got a couple of b flows
Big Fluff wrote:C'mon Teddy.... what's the latest, what ya been doin ?
If you've got stock pistons then 8:1 is about the absolute limit, if you're running flat top 'forged' turbo pistons then 9:1 would be more like it.
Also, you won't be able to run much boost with std pistons, sure they're strong as hell for nat asp but seem to disintegrate when being force fed with a turbo.![]()
'Fastbyme' will no doubt be able to steer you on this project, he's quite a knowledgeable guy on blown bikes
