Output shaft O -ring
sprint
#1 PostAuthor: sprint » Wed Apr 01, 2015 2:58 pm
Can somebody please advise the dimensions of the Z900 output shaft O-ring, 92055-035, #31 page 12 of Z Power parts list.
Its the one that sits between the bearing and the sprocket collar.
#2 PostAuthor: z1bman » Wed Apr 01, 2015 3:56 pm
22mm x1.5mm thickness
sprint
#3 PostAuthor: sprint » Wed Apr 01, 2015 4:10 pm
z1bman wrote:22mm x1.5mm thickness
DogsbolloxofZ1B
#4 PostAuthor: DogsbolloxofZ1B » Wed Apr 01, 2015 7:47 pm
Not wanting to say you're wrong but that seems very thick its more like 0.75mm
Diameter cross section. Its very thin and hard to see when fitted. You mean the one behind the sprocket collar? I stand to be corrected but will take a look through my spares😄
Mike
#5 PostAuthor: z1bman » Wed Apr 01, 2015 7:53 pm
sprint
#6 PostAuthor: sprint » Thu Apr 02, 2015 6:38 pm
The one in the gasket kit supplied by Z Power has the correct I/D of 22 mm but it has a thickness of 2.3 mm?
Is that too big or it will compress OK between the inside chamfers of the bearing inner race and the sprocket collar to provide an adequate seal? Or does it need to be replaced for a 1.5 mm one?
#7 PostAuthor: z1bman » Thu Apr 02, 2015 6:54 pm
i think 2.3mm is a bit thick it is possible it might split
DogsbolloxofZ1B
#8 PostAuthor: DogsbolloxofZ1B » Fri Apr 03, 2015 6:31 pm
92055-035 is OD24mm x ID22mm so CSA Diameter is 1mm dead.
