Laquer over decals
ADE
Laquer over decals
#1 PostAuthor: ADE » Sat Apr 04, 2015 7:29 pm
I would like your advice do you laquer over decl sets or not.Thinking of a yellow Z1b set?
Cheers Ade
jez1100r
#2 PostAuthor: jez1100r » Sat Apr 04, 2015 8:27 pm
It depends on the venal that they are made from .some are designed to be lacquered over others it will just peel off especially if the lacquer is backed in an oven
sprint
#3 PostAuthor: sprint » Sat Apr 04, 2015 8:30 pm
Depends on if they are the laminated type? If they are then they will have a fairly durable top surface and no need to lacquer them. If they are not the laminated type then when you polish etc the top surface will slowly be rubbed away and fade. In that case you can use some Gold Size the seal the surface.
freddyz1r
#4 PostAuthor: freddyz1r » Sun Apr 05, 2015 6:53 am
Ade, I'm no expert, but lacquering over the vinyl is standard practice :??
As sprint already said the vinyl might catch :?:
to be sure about what you are doing why not contact 'image works' @ ilkeston.
http://www.the-image-works.co.uk/
they do a lot of 'sticker sets' (including for painters on here), and they are very knowledgeable and patient when asking them questions :oops: :roll:
Cheerz freddy :D
freddyz1r
PUM 329
malmojoe
#5 PostAuthor: malmojoe » Sun Apr 05, 2015 7:22 am
From instructions that came with my R2 decals from Diablo : Let the paint cure for about a week before applying decals incase of shrinkage - then flatten with wet and dry, spray a mist of slightly soapy water on beneath the decals so that you can make small adjustments, use soft plastic blade to smoothe out. Leave another week or so for any air/water bubbles to shrink then clear coat.
Originally on the ELRs only the tank was clear coated after decals, I am guessing to protect against petrol. The other stripes were not, but a jet washer will blow them off.
I would definitely clear coat them. No reason not too really.
ADE
#6 PostAuthor: ADE » Sun Apr 05, 2015 8:12 am
Cheers for the reply i e-mailed image works yesterday going on what everyone recomends.My main concern was fitting them correctly and i see they will fit them.Just dont want to have to buy another set in case i make a mistake fitting them
Ade
