AAAAARRRRRGGGGHHHHH!!!! 26mm Carb Pilot screw and limiter
Gus
#1 PostAuthor: Gus » Fri Apr 10, 2015 6:23 pm
Hi Guys.
This is driving me nuts!!!!!!
26mm carbs with the pilot screw and limiter fitted underneath the carb's between the carb and inlet.
The Kawasaki manual says mark the limiter/screw and turn the screw in until it lightly seats, REMEMBER THIS and remove the screw.
GUESS WHO DIDN'T!!!!!!!!!!!!!!!!!!!!
Can anybody tell me what the number of turns out is from lightly seated?
I know this is a fuel adjustment screw and NOT an air screw but I'm not really undersatnding the technical stuff, like when it is set it has the plastic limiter on it.
Cheers guys
Gus
"Set the GRINDER on it"
#2 PostAuthor: Pigford » Fri Apr 10, 2015 6:32 pm
Dunno for sure - but usually 1+1/2 to 2 out :|
Z1parR
#3 PostAuthor: Z1parR » Fri Apr 10, 2015 6:46 pm
Kwak manual says 1 1/4 +or- 1/8 for 1000A1 .
0172 . Geoff Parr
Users browsing this forum: Bing [Bot] and 64 guests
