1105 Liner fitting
1105 Liner fitting
#1 PostAuthor: ZedHead » Thu Apr 23, 2015 3:39 pm
Does a 1015 cylinder block need to be bored out to fit an 1105 liner and piston kit? Outside diameter of the 1105 liner is 81.25 mm.
#2 PostAuthor: Ginger Bear » Thu Apr 23, 2015 3:44 pm
1105 is the largest you can go with a standard liner, although some prefer to stop at 1075 as the wall of the liner is fairly thin around the bottom.
Didn't have any problems with this though at 1105cc. :D
#3 PostAuthor: ZedHead » Thu Apr 23, 2015 3:56 pm
Now that is tasty :D
A customer of mine has a set of f*&^!£d barrels with Wiseco K1105 kit and liners fitted. The question is could he go back to standard? I suspect not if the block has been modified to take the 81.25 O.D liners.
Just want to be sure of what i am saying.
#4 PostAuthor: Ginger Bear » Thu Apr 23, 2015 4:02 pm
Sorry Dave, I think I misunderstood your question. :oops: :oops:
If the liners are oversize, just bore it out even bigger. :lon :lon
#5 PostAuthor: ZedHead » Thu Apr 23, 2015 4:30 pm
Thanks GB.
I think i got it :P
#6 PostAuthor: Ginger Bear » Thu Apr 23, 2015 7:07 pm
Dave, I've got a set of 1015 barrels to 1105 (bores no good) but with standard 75.5mm liners. Has minor fin damage on one end. £20 posted if they're any good to you?
Pic's coming.
#7 PostAuthor: Ginger Bear » Thu Apr 23, 2015 7:15 pm
#8 PostAuthor: ZedHead » Thu Apr 23, 2015 7:22 pm
Cheers mate. As i said it is for a customer so he would be happy to pay. I will let you know.
KWACKERZ1
barrels
#9 PostAuthor: KWACKERZ1 » Fri Apr 24, 2015 2:21 pm
GB, I'LL Have them if Dave does not want them please.
#10 PostAuthor: ZedHead » Thu Apr 30, 2015 8:27 am
Thanks for the offer GB my customer has decided to take his big bore liners out to 74mm - 1135cc.
KWACKERZ1, looks like these could be yours :D
Re: barrels
#11 PostAuthor: Ginger Bear » Thu Apr 30, 2015 3:34 pm
KWACKERZ1 wrote:GB, I'LL Have them if Dave does not want them please.
All yours then Phil. :D
PM me your addy again :roll: & I'll get 'em packed up.
KWACKERZ1
#12 PostAuthor: KWACKERZ1 » Thu Apr 30, 2015 4:19 pm
Thanks. will do.
