Any previous experience on summink that works, gents
Hinckley wrote:Loctite 641 would be adequate.
Coose wrote:If you never want them to budge again I have a spare small tube of 648 that you can have if you PM me your address. 648 is good to 180DegC which might be enough?
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627682305
Hinckley wrote:I use it for securing bearings in cylinder heads, gearboxes and axles, also for retaining bushes in power valves and valve guides - never had an issue - have to heat them with a naked flame to remove them.
You can go up to 638 or 648 180°C or 278 +200°C.
Users browsing this forum: Bing [Bot] and 30 guests
