Z1000J rear wheel
Coose
Z1000J rear wheel
#1 PostAuthor: Coose » Wed May 06, 2015 10:05 am
Morning all,
Having contemplated a number of options and having picked up a bargain set of 320mm discs I'm going to try my front Astralite in my Z1000J as it should be a simple and reversible installation. As it's a 3" rim I could ideally do with a slightly wider rear so that I can at least run a 130 on the back to suit a 110 front.
So, I am on the lookout for a rear wheel to suit, with maybe a 3" rim or so that will fit in the stock swinging arm. Ideally I'd like something to drop straight in, but if not it won't be the end of the world. Another Astralite would be nice, though I'm not too hopeful so does anyone have anything kicking about?
Cheers,
coose
