Z1-R Gas Cap Rubber Gasket 11009-1036 Needed Please
Hi People,
Does anyone have any leads on where I could track down a new sealing rubber for a Z1-R fuel cap please?
part code - 11009-1036
Have tried the usual suspects but it is no longer available.
It is the one from the original 1978 13 litre low profile tank I am after.
Thanks for looking.
From Mark
Thanks for looking.
From Mark
I will certainly keep looking then.
Would you mind keeping your eye out for one in your neck of the woods ?
Would be grateful of a tip off if you spot one.
Or does anyone else know of another one that will fit ?
I might get some measurements off mine - there must be similar sized gas caps from later models surely.
from Mark
from Mark
Cheers Kev,
I will come back to you on that offer.
Need to get my best one onto the bike tank - then I can get the one from the spare touring tank off for analysis and possible fabrication.
Thanks for that Paul,
I am there tomorrow for some tube clips and a cable - so I will ask them to show me one.
from Mark
from Mark
Update from Cradley Kawa -
We tried the Z1000 A2 etc. gasket but too big.
Have drawn them a template with all the dimensions marked on and they will see if there is anything close and let me know.
Will put the dimensions on this thread when I get home.
From Mark
From Mark
These are the measurements I am trying to match -
top inner diameter 33.90 mm (touches tank neck)
rear inner diameter 37.5 mm (nearest side to cap)
outer diameter 48.45 mm (this could be a bit + or -)
Has anyone got one off any of their bikes that matches these sizes ??
Thanks a lot.
Thanks a lot.
Keep an eye on Buyee.jp even better if you know someone in Japan. This one looks like a secondhand cap, hard to decipher.
http://buyee.jp/item/yahoo/auction/e161193977
Thanks for trying down there for me.
Could you keep an eye on your local eBay as well please?
From Mark
From Mark
- steve bowdler
Cheers Steve,
Have sent them a message.
From Mark
From Mark
Just a thought on this, a lot of the old type rubber seems to sucumb to our new nasty ethanol petrol ,make sure whatever you use is ethanol resistant,it even ate away the innards of some fuel lines on my Gs last year depositing bits in the carbs,would be expensive fuel cap seal if gas leached out onto the paint.Thimking about it bet the old fuel cap seals are not Ethanol proof
Since i have used additive and Ethanol proof fuel lines though no more probs ....Yet!!!!!
