http://kzrider.com/component/option,com ... itstart,0/
Street Racer Project on kz rider forum
Hope this link works ok, this is worth a look, something completly different
- paul doran
Did you see the weight he was aiming for Paul 425 lbs dry!
I dont really like all that bracing on the swing arm but I love just about everything else about it, particularly that its going to be so different especially for a yank
I think the main advantage of using a dresda swing arm is the taper bearings I wonder if he is using the standard bearings if so it will be a real weak spot!
Auld Git
