Starter motor
tlc
Starter motor
#1 PostAuthor: tlc » Sat May 16, 2015 4:03 pm
Today was a good day. The Asphalt Cowboy ran up for the first time. However, selecting the best of the 2 starters I have it is noticeably lazy. Spinning it up directly from a battery it all sounds good but I would suspect there is a problem within that means it doesn't have the power to spin the motor adequately.
I have seen an assembly which contains all the brushes and springs (genuine K) for sale at a reasonable cost.
I would appreciate any experience others have on rebuilding starters and their success in defeating a lazy starter motor.
PAULJAC47
#2 PostAuthor: PAULJAC47 » Sat May 16, 2015 5:12 pm
Could be a bad segment on the rotor,clean up well and test continuity between segments,clean care fully with sharp knife between segments,make sure brushes are good and making good contact...Paul J
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Sat May 16, 2015 5:19 pm
Chris,
I think I have one I could loan you if your stuck whilst you get it sorted.
Pm me if you want to borrow it.
tlc
#4 PostAuthor: tlc » Sat May 16, 2015 5:36 pm
That's very kind.
I do have one on my J if they are the same. I'm probably not in any rush as there are a couple of things holding me up at the mo.
Really it's experience of refurbishing I'm after and Paul J has some good suggestions. My first job was rebuilding starters so I'm familiar. It's just that these motors are so small I wondered if they are even worth doing.
Brush kit ordered now so at least I'll give it a go
Mark Tiller
#5 PostAuthor: Mark Tiller » Sat May 16, 2015 6:13 pm
Just a thought...have you connected the engine earth connection?
07962421462
Users browsing this forum: Gus and 109 guests
