This is all new to me but I have a charging problem.
As far as I can tell the Reg Rec is good. I've done the static resistance tests.
It's the output from the stator I think I need help with.
Any pointers chaps?
UniTrak charging
UniTrak charging
Hi Chris, should be standard 3 phase genny, with engine running you should get about 50 volts ac across any 2 and all of the three output wires in any combo,you should get about 14.6 volts dc across the battery at about 3k revs,Cheers Paul J
