Z1000 mk2 clutch pusher
Jerry
President
President
#1 PostAuthor: Jerry » Sun May 17, 2015 12:16 pm
Since putting a mark two primary shaft in the Moriwaki, I've learnt, after all these years, that an early clutch pusher and ball bearing won't fit as they are a bigger diameter - has anyone got one under their workbench???
Yellow
Clutch pusher
#2 PostAuthor: Yellow » Sun May 17, 2015 6:36 pm
Is tImagehis the One Jerry?
Jerry
President
President
#3 PostAuthor: Jerry » Sun May 17, 2015 7:36 pm
Nope, The other end, that goes inside the clutch basket. Thanks for the reply though.
Yellow
#4 PostAuthor: Yellow » Sun May 17, 2015 7:48 pm
OK, sorry don't have that bit.
Z1parR
#5 PostAuthor: Z1parR » Sun May 17, 2015 8:29 pm
I'm sure i have a MK11 one Jerry .
44mm head dia , 10mm shaft dia , 9.5mm ball bearing dia .
0172 . Geoff Parr
Jerry
President
President
#6 PostAuthor: Jerry » Mon May 18, 2015 12:23 pm
Thanks For looking, but the 10mm shaft size is the earlier type.
